Randomized incremental construction of Delaunay triangulations of nice point sets - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Jean-Daniel Boissonnat
  • Fonction : Auteur
  • PersonId : 935453
Kunal Dutta
  • Fonction : Auteur
  • PersonId : 1025303
Marc Glisse
Randomized incremental construction(RIC) is one of the most important paradigms for buildinggeometric data structures. Clarkson and Shor developed a general theory that led to numerous algorithms that are both simple and efficient in theory and in practice. Randomized incremental constructions are most of the time space and time optimal in the worst-case, as exemplified by the construction of convex hulls, Delaunay triangulations and arrangements of line segments. However, the worst-case scenario occurs rarely in practice and we would like tounderstand how RIC behaves when the input is nice in the sense that the associated output issignificantly smaller than in the worst-case. For example, it is known that the Delaunay triangulations of nicely distributed points on polyhedral surfaces in $E3$ has linear complexity, as opposed to aworst-case quadratic complexity. The standard analysis does not provide accurate bounds on thecomplexity of such cases and we aim at establishing such bounds in this paper. More precisely, we will show that, in the case of nicely distributed points on polyhedral surfaces, the complexity of the usual RIC is $O(nlogn)$, which is optimal. In other words, without any modification, RIC nicely adapts to good cases of practical value.Our proofs also work for some other notions of nicely distributed point sets, such as $(ε,κ)$-samples.Along the way, we prove a probabilistic lemma for sampling without replacement, which may be of independent interest.
esa.pdf (530.91 Ko) Télécharger le fichier
hal-02185566 , version 1 (16-07-2019)
Jean-Daniel Boissonnat, Olivier Devillers, Kunal Dutta, Marc Glisse. Randomized incremental construction of Delaunay triangulations of nice point sets. ESA 2019 - 27th Annual European Symposium on Algorithms, Sep 2019, Munich, Germany. ⟨10.4230/LIPIcs.ESA.2019.22⟩. ⟨hal-02185566⟩
105 Consultations
166 Téléchargements
