Hardness results on Voronoi, Laguerre and Apollonius diagrams - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We show that converting Apollonius and Laguerre diagrams from an already built Delaunay triangulation of a set of n points in 2D requires at least Ω(n log n) computation time. We also show that converting an Apollonius diagram of a set of n weighted points in 2D from a Laguerre diagram and vice-versa requires at least Ω(n log n) computation time as well. Furthermore , we present a very simple randomized incremental construction algorithm that takes expected O(n log n) computation time to build an Apollonius diagram of non-overlapping circles in 2D.
CCCG_2019_paper_40.pdf (342.7 Ko) Télécharger le fichier
Format : Figure, Image
hal-02186693 , version 1 (17-07-2019)
  • HAL Id : hal-02186693 , version 1
Kevin Buchin, Pedro M. M. de Castro, Olivier Devillers, Menelaos Karavelas. Hardness results on Voronoi, Laguerre and Apollonius diagrams. CCCG 2019 - Canadian Conference on Computational Geometry, Aug 2019, Edmonton, Canada. ⟨hal-02186693⟩
111 Consultations
340 Téléchargements
