New Discrete Logarithm Computation for the Medium Prime Case Using the Function Field Sieve - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Advances in Mathematics of Communications Année : 2022
The present work reports progress in discrete logarithm computation for the general medium prime case using the function field sieve algorithm. A new record discrete logarithm computation over a 1051-bit field having a 22-bit characteristic was performed. This computation builds on and implements previously known techniques. Analysis indicates that the relation collection and descent steps are within reach for fields with 32-bit characteristic and moderate extension degrees. It is the linear algebra step which will dominate the computation time for any discrete logarithm computation over such fields.
2020-113.pdf (311.17 Ko) Télécharger le fichier
hal-02964002 , version 1 (12-10-2020)
Paternité
Madhurima Mukhopadhyay, Palash Sarkar, Shashank Singh, Emmanuel Thomé. New Discrete Logarithm Computation for the Medium Prime Case Using the Function Field Sieve. Advances in Mathematics of Communications, 2022, 16 (3), pp.449-464. ⟨10.3934/amc.2020119⟩. ⟨hal-02964002⟩
106 Consultations
101 Téléchargements
