Polynomial Algorithm For Learning From Interpretation Transition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2021
Learning from interpretation transition (LFIT) automatically constructs a model of the dynamics of a system from the observation of its state transitions. The previously proposed General Usage LFIT Algorithm (GULA) serves as the core block to several methods of the framework that capture different dynamics. But its exponential complexity limits the use of the whole framework to relatively small systems. In this paper, we introduce an approximated algorithm (PRIDE) which trades the completeness of GULA for a polynomial complexity.
ilp21_extended_abstract_pride.pdf (295.13 Ko) Télécharger le fichier
Ribeiro_IJCLR_PRIDE_Poster.pdf (791.05 Ko) Télécharger le fichier
hal-03347026 , version 1 (16-09-2021)
  • HAL Id : hal-03347026 , version 1
Tony Ribeiro, Maxime Folschette, Morgan Magnin, Katsumi Inoue. Polynomial Algorithm For Learning From Interpretation Transition. 1st International Joint Conference on Learning & Reasoning, Oct 2021, (virtual), Greece. . ⟨hal-03347026⟩
99 Consultations
92 Téléchargements
