Schema.org : How is it used? - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Schema.org defines a shared vocabulary for semantically annotating web pages. Due to the vast and diverse nature of the contributed annotations, it is not easy to understand the widespread use of Schema.org. In this poster, we rely on the characteristic sets computed from the web data commons datasets to provide insights into property combinations on various websites. Thanks to in-depth experiments, this poster establishes a comprehensive observatory for schema.org annotations, visually presenting the most frequently used classes, commonly used combinations of properties per class, the average number of filled properties per class, and the classes with the greatest property coverage. These findings are valuable for both the communities involved in defining Schema.org vocabularies and the users of these vocabularies.
iswc2023_poster.pdf (901.15 Ko) Télécharger le fichier
hal-04250523 , version 1 (17-11-2023)
hal-04250523 , version 2 (29-04-2024)
Paternité
  • HAL Id : hal-04250523 , version 2
Minh-Hoang Dang, Alban Gaignard, Hala Skaf-Molli, Pascal Molli. Schema.org : How is it used?. International Semantic Web Conference (ISWC) 2023, Nov 2023, Athens, France. ⟨hal-04250523v2⟩
115 Consultations
78 Téléchargements
