s'authentifier
version française rss feed
inria-00000126, version 1
Wide-Area Communication for Grids: An Integrated Solution to Connectivity, Performance and Security Problems
Alexandre Denis (Auteur à contacter de préférence) 1, Olivier Aumage 2, Rutger Hofman 3, Kees Verstoep 3, Thilo Kielmann 3, Henri E. Bal 3
the Thirteenth IEEE International Symposium on High-Performance Distributed Computing (HPDC'13) (2004)
Résumé : Grid computing applications are challenged by current wide-area networks: firewalls, private IP addresses and network address translation (NAT) hamper connectivity, the TCP protocol can hardly exploit the available bandwidth, and security features like authentication and encryption are usually difficult to integrate. Existing systems (like GridFTP, JXTA, SOCKS) each address only one of these issues. However, applications need to cope with all of them, at the same time. Unfortunately, existing solutions are often not easy to combine, and a particular solution for one subproblem may reduce the applicability or performance of another. In this paper, we identify the building blocks that are needed for connection establishment and efficient link utilization. We present an integrated solution, implemented within the Java-based Ibis runtime system. Our NetIbis implementation lets applications span multiple sites of a grid, and copes with firewalls, local IP addresses, secure communication, and TCP bandwidth problems.
  • 1 :  PARIS (INRIA - IRISA)
  • CNRS : UMR6074 – INRIA – École normale supérieure de Cachan - ENS Cachan – INSA Rennes – Université de Rennes 1
  • 2 :  RUNTIME (INRIA Futurs)
  • INRIA – CNRS : UMR5800 – Université Sciences et Technologies - Bordeaux I – École Nationale Supérieure d'Électronique, Informatique et Radiocommunications de Bordeaux (ENSEIRB)
  • 3 :  IBIS (IBIS)
  • Vrije Universiteit
  • Domaine : Informatique/Réseaux et télécommunications
  • Mots-clés : NetIbis – Grid computing – network communication – firewall – TCP splicing
  • inria-00000126, version 1
  • oai:hal.inria.fr:inria-00000126
  • Contributeur :
  • Soumis le : Jeudi 23 Juin 2005, 16:20:02
  • Dernière modification le : Jeudi 6 Novembre 2008, 12:10:14
tous les articles de la base du CCSd...
