Using Neural Dynamics to Switch Attention - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
Julien Vitay
Nicolas P. Rougier
We present a distributed and dynamic model of visual attention based on the Continuum Neural Field Theory that allows to sequentially focus salient locations in an image. A working memory system ensures that the corresponding objects are only focused once, even if they are moving around, such that the visual search is efficient. The model has been implemented on a robotic platform in order to search for natural objects such as fruits.
ijcnn.pdf (1.27 Mo) Télécharger le fichier
inria-00000144 , version 1 (05-07-2005)
  • HAL Id : inria-00000144 , version 1
Julien Vitay, Nicolas P. Rougier. Using Neural Dynamics to Switch Attention. International Joint Conference on Neural Networks - IJCNN'05, Jul 2005, Montreal, Canada. ⟨inria-00000144⟩
96 Consultations
147 Téléchargements
