Impacts of Packet Scheduling and Packet Loss Distribution on FEC Performances: Observations and Recommendations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2005
Forward Error Correction (FEC) is commonly used for content broadcasting. The performance of the FEC codes largely vary, depending in particular on the object size and on the number of parity packets produced, and these parameters have already been studied in detail by the community. However the FEC performances are also largely dependent on the packet scheduling used during transmission and on the loss pattern introduced by the channel. Therefore this work analyzes their impacts on three FEC codes: LDGM Staircase, LDGM Triangle, two large block FEC codes, and Reed-Solomon. Thanks to this analysis, we define several recommendations on how to best use these codes, depending on the test case and on the channel, which turns out to be of utmost importance.
RR-5578.pdf (360.36 Ko) Télécharger le fichier
inria-00000146 , version 1 (07-07-2005)
  • HAL Id : inria-00000146 , version 1
Christoph Neumann, Vincent Roca, Aurelien Francillon, David Furodet. Impacts of Packet Scheduling and Packet Loss Distribution on FEC Performances: Observations and Recommendations. [Research Report] RR-5578, INRIA. 2005, pp.29. ⟨inria-00000146⟩
169 Consultations
223 Téléchargements
