s'authentifier
version française rss feed
inria-00000170, version 1
Asymptotic expansion of the solution of Maxwell's equations in polygonal plane domains
Boniface Nkemzi () 1
(2005)
Résumé : This paper is mainly concerned with the structure of the singular and regular parts of the solution of time-harmonic Maxwell's equations in polygonal plane domains. The asymptotic behaviour of the solution near corner points of the domain is studied by means of discrete Fourier transformation. A detailed functional analysis of the solution shows that the boundary value problem does not belong locally to~$H^2$ when the boundary of the domain has non-acute angles, and explicit formulas for the singularity functions and their corresponding coefficients are given.
  • Domaine : Mathématiques/Equations aux dérivées partielles
  • Mots-clés : Maxwell's equations – singularities – Fourier method
  • inria-00000170, version 1
  • oai:hal.inria.fr:inria-00000170
  • Contributeur :
  • Soumis le : Mardi 19 Juillet 2005, 19:35:18
  • Dernière modification le : Jeudi 25 Septembre 2008, 14:11:06
tous les articles de la base du CCSd...
