Resource analysis by sup-interpretation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
We propose a new method to control memory resources by static analysis. For this, we introduce the notion of sup-interpretation which bounds from above the size of function outputs. This method applies to first order functional programming with pattern matching. This work is related to quasi-interpretations but we are now able to determine resources of more algorithms and it is easier to perform an analysis with this new tools.
fullpaper.pdf (553.43 Ko) Télécharger le fichier
inria-00000661 , version 1 (10-11-2005)
inria-00000661 , version 2 (09-01-2008)
Jean-Yves Marion, Romain Péchoux. Resource analysis by sup-interpretation. Eighth International Symposium on Functional and Logic Programming - FLOPS 2006, Apr 2006, Fuji Susono, Japan. pp.163--176, ⟨10.1007/11737414_12⟩. ⟨inria-00000661v2⟩
104 Consultations
229 Téléchargements
