Avoiding the Bloat with Stochastic Grammar-based Genetic Programming - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2001
Alain Ratle
  • Fonction : Auteur
  • PersonId : 832234
Michèle Sebag
  • Fonction : Auteur
  • PersonId : 836537
The application of Genetic Programming to the discovery of empirical laws is often impaired by the huge size of the search space, and consequently by the computer resources needed. In many cases, the extreme demand for memory and CPU is due to the massive growth of non-coding segments, the introns. The paper presents a new program evolution framework which combines distribution-based evolution in the PBIL spirit, with grammar-based genetic programming; the information is stored as a probability distribution on the gra mmar rules, rather than in a population. Experiments on a real-world like problem show that this approach gives a practical solution to the problem of intron growth.
neo_ea01.pdf (184.46 Ko) Télécharger le fichier
inria-00001095 , version 1 (05-02-2006)
Alain Ratle, Michèle Sebag. Avoiding the Bloat with Stochastic Grammar-based Genetic Programming. Evolution Artificielle 01, 2001, Le Creusot, France. pp.254-266. ⟨inria-00001095⟩
99 Consultations
188 Téléchargements
