Input Impedance of the Arterial System Using Parametric Models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
In this work, we propose to use parametric models for the estimation of arterial tree input impedance. The results of this new method are compared with those of the standard method based on the Fast Fourier Transform (FFT). The comparison is first made with pressure and flow measurements on a calf, then with human blood pressure measurements completed by blood flow data simulated from a soliton+windkessel model. The input impedance is calculated both at aorta and finger. As illustrated by the numerical results, the advantage of the proposed parametric method is its smooth impedance estimations, whereas the standard FFT method yields more disturbed results.
Laleg_Sorine_Zhang.pdf (234.85 Ko) Télécharger le fichier
inria-00001185 , version 1 (30-03-2006)
  • HAL Id : inria-00001185 , version 1
Taous-Meriem Laleg, Michel Sorine, Qinghua Zhang. Input Impedance of the Arterial System Using Parametric Models. ICES, May 2006, Algérie. ⟨inria-00001185⟩
199 Consultations
864 Téléchargements
