Event Systems and Access Control - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
We consider the interpretations of notions of access control (permissions, interdictions, obligations, and user rights) as run-time properties of information systems specified as event systems with fairness. We give proof rules for verifying that an access control policy is enforced in a system, and consider preservation of access control by refinement of event systems. In particular, refinement of user rights is non-trivial; we propose to combine low-level user rights and system obligations to implement high-level user rights.
final.pdf (117.29 Ko) Télécharger le fichier
inria-00001262 , version 1 (21-04-2006)
Dominique Méry, Stephan Merz. Event Systems and Access Control. Sixth International IFIP WG 1.7 Workshop on Issues in the Theory of Security, Mar 2006, Vienna/Austria, pp.40-54. ⟨inria-00001262⟩
134 Consultations
70 Téléchargements
