A Directory Based Repository for OSI Management Information Knowledge - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2002
This document presents an approach to store GDMO (Guidelines for the Definitio- n of Managed Objects) specifications within a LDAP (Lightweigth Directory Access Protocol) directory server. It defines a set of LDAP object classes and attributes enabling the representation of any GDMO model within the directory. It also presents the implementation provided within the latest distribution of the MODERES-Java toolkit together with a Java API that facilitates the access to the stored GDMO specifications.
Autre [cs.OH]
RT-0264.pdf (335.5 Ko) Télécharger le fichier
inria-00069910 , version 1 (19-05-2006)
  • HAL Id : inria-00069910 , version 1
Olivier Festor, Nizar Ben Youssef. A Directory Based Repository for OSI Management Information Knowledge. [Technical Report] RT-0264, INRIA. 2002, pp.36. ⟨inria-00069910⟩
79 Consultations
304 Téléchargements
