s'authentifier
version française rss feed
inria-00070162, version 1
Geometric, topological and contact analysis of interfaces in macro-molecular complexes: from the atomic to the complex scale using Intervor
Frederic Cazals () 1
N° RR-5864 (2006)
Résumé : Understanding the sociology of interactions between the proteins encoded in a genome is a central question of structural biology, and interface models between molecules forming a complex are instrumental in this perspective. Qualifying interface atoms as atoms loosing solvent accessibility in the complex, or pairs of atoms within a distance threshold, several interface models have been proposed. Yet, until recently, no interface model existed to answer coherently (if at all) the following questions: can one bridge the gap from atoms loosing solvent accessibility to interface pairs? is the interface flat or curvy? is it connected or not (does it have a multi-patch structure)? is a connected component of the interface simply connected or not (does it have a hole)? what is precisely the role played by interface structural water? Using the $\alpha$-complex of the Van der Waals balls, a construction derived from the Voronoi diagram, we designed such an interface model, and validated it on the usual database of co-crystallized protein-protein complexes. This paper is a methodological paper aiming at easing the access of the interface model to structural biologists. As such, the paper overviews: (i) the geometric principles underlying the interface model (ii) the definitions of the interface and its extension to accommodate structural water (iii) the statistics one can compute from the interface model (iv) the Software Intervor and the associated web site. These presentations are accompanied by illustrations and insights on protein - protein complexes.
  • Domaine : Informatique/Autre
  • Mots-clés : STRUCTURAL BIOLOGY – MOLECULAR MODELING – MOLECULAR INTERFACES – VORONOÏ DIAGRAMS
  • Référence interne : RR-5864
  • inria-00070162, version 1
  • oai:hal.inria.fr:inria-00070162
  • Contributeur :
  • Soumis le : Vendredi 19 Mai 2006, 19:17:51
  • Dernière modification le : Mardi 4 Novembre 2008, 15:46:32
tous les articles de la base du CCSd...
