A note on maximally repeated sub-patterns of a point set - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2005
We answer a question raised by P. Brass on the number of maximally repeated sub-patterns in a set of $n$ points in $\mathbbR^d$. We show that this number, which was conjectured to be polynomial, is in fact $\Theta(2^n/2)$ in the worst case, regardless of the dimension $d$.
Autre [cs.OH]
RR-5773.pdf (176.71 Ko) Télécharger le fichier
inria-00070247 , version 1 (19-05-2006)
  • HAL Id : inria-00070247 , version 1
Véronique Cortier, Xavier Goaoc, Mira Lee, Hyeon-Suk Na. A note on maximally repeated sub-patterns of a point set. [Research Report] RR-5773, INRIA. 2005, pp.5. ⟨inria-00070247⟩
211 Consultations
197 Téléchargements
