A finite element method with edge oriented stabilization for the time-dependent Navier-Stokes equations: space discretization and convergence - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2005
Erik Burman
  • Fonction : Auteur
This work focuses on the numerical analysis of a finite element method with edge oriented stabilization for the unsteady incompressible Navier-Stokes equations. Incompressibility and convective effects are both stabilized adding an interior penalty term giving $L^2$-control of the jump of the gradient of the approximate solution over the internal edges. Using continuous equal-order finite elements for both velocities and pressures, in a space semi-discretized formulation, we prove convergence of the approximate solution. The error estimates hold irrespective of the Reynolds number, and hence also for the incompressible Euler equations, provided the exact solution is smooth.
RR-5630.pdf (449.6 Ko) Télécharger le fichier
inria-00070378 , version 1 (19-05-2006)
  • HAL Id : inria-00070378 , version 1
Erik Burman, Miguel Angel Fernández. A finite element method with edge oriented stabilization for the time-dependent Navier-Stokes equations: space discretization and convergence. [Research Report] RR-5630, INRIA. 2005, pp.42. ⟨inria-00070378⟩
106 Consultations
177 Téléchargements
