Iterated importance sampling in missing data problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computational Statistics and Data Analysis Année : 2006
Gilles Celeux
Jean-Michel Marin
Christian Robert
Missing variable models are typical benchmarks for new computational techniques in that the ill-posed nature of missing variable models offer a challenging testing ground for these techniques. This was the case for the EM algorithm and the Gibbs sampler, and this is also true for importance sampling schemes. A population Monte Carlo scheme taking avantage of the latent structure of the problem is proposed. The potential of this approach and its specifics in missing data problems are illustrated in settings of increasing difficulty, in comparison with existing approaches. The improvement brought by a general Rao-Blackwellisation technique is also discussed.
RR-5534.pdf (771.18 Ko) Télécharger le fichier
inria-00070473 , version 1 (19-05-2006)
  • HAL Id : inria-00070473 , version 1
Gilles Celeux, Jean-Michel Marin, Christian Robert. Iterated importance sampling in missing data problems. Computational Statistics and Data Analysis, 2006, 50 (12), pp.3386-3404. ⟨inria-00070473⟩
126 Consultations
252 Téléchargements
