Numerical Investigations of Turbulent Flow Past a Generic Airship - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
Turbulent separated flows around an airship-like geometry (a prolate spheroid 6:1) are investigated using three turbulence modelings based on statistical and Large Eddy Simulation (LES) approaches. The turbulence models used in the simulations are a standard high Reynolds $k$-$\varepsilon$ model, a Smagorinsky LES model and a variational multiscale LES one. The flow of interest is characterized by a relatively low Mach number ($Mach =0.15$), an angle of attack set to $20^\circ$ and a Reynolds number fixed to $4´ 10^4$. The three-dimensional compressible Navier-Stokes equations equipped with the previous turbulent models are discretized by a mixed finite element/finite volume method. The simulations show that the primary longitudinal vortex is predicted by the three models, but only the VMS-LES model predicts a secondary vortical flow structure that is observed in experimental studies.
RR-5455.pdf (980.5 Ko) Télécharger le fichier
inria-00070551 , version 1 (19-05-2006)
  • HAL Id : inria-00070551 , version 1
Kamal El Omari, Éric Schall, Bruno Koobus, Alain Dervieux. Numerical Investigations of Turbulent Flow Past a Generic Airship. [Research Report] RR-5455, INRIA. 2006, pp.22. ⟨inria-00070551⟩
176 Consultations
194 Téléchargements
