s'authentifier
version française rss feed
inria-00070573, version 1
Learning Surfaces by Probing
Jean-Daniel Boissonnat () 1, Leonidas J. Guibas, Steve Oudot
N° RR-5434 (2004)
Résumé : We consider the problem of discovering a smooth unknown surface S bounding an object O in R^3. The discovery process consists of moving a point probing device in the free space around O so that it repeatedly comes in contact with S. We propose a probing strategy for generating a sequence of surface samples on S from which a triangulated surface can be generated which approximates S within any desired accuracy. We bound the number of probes and the number of elementary moves of the probing device. Our solution is an extension of previous work on Delaunay refinement techniques for surface meshing. The approximating surface we generate enjoys the many nice properties of the meshes obtained by those techniques, e.g. exact topological type, nomal approximation, etc.
  • Domaine : Informatique/Autre
  • Mots-clés : MANIFOLD LEARNING / BLIND SURFACE APPROXIMATION / INTERACTIVE SURFACE RECONSTRUCTION / SURFACE MESHING / DELAUNAY REFINEMENT
  • Référence interne : RR-5434
  • inria-00070573, version 1
  • oai:hal.inria.fr:inria-00070573
  • Contributeur :
  • Soumis le : Vendredi 19 Mai 2006, 20:55:13
  • Dernière modification le : Mercredi 31 Mai 2006, 14:24:24
tous les articles de la base du CCSd...
