On the Complexity of Bandwidth Allocation in Radio Networks with Steady Traffic Demands - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2004
In this paper we define and study a call scheduling problem that is motivated by radio networks. In such networks the physical space is a common resource that nodes have to share, since concurrent transmissions cannot be interfering. We study how one can satisfy steady bandwidth demands according to this constraint. This leads to the definition of a call scheduling problem. We show that it can be relaxed into a simpler problem: The call weighting problem, which is almost a usual multi-commodity flow problem, but the capacity constraints are replaced by the much more complex notion of non interference. Not surprisingly this notion involve independent sets, and we prove that the complexity of the call weighting problem is strongly related to the one of the independent set problem and its variants (max-weight, coloring, fractional coloring). The hardness of approximation follows when the interferences are described by an arbitrary graph. We refine our study by considering some particular cases for which efficient polynomial algorithm can be provided: the Gathering in which all the demand are directed toward the same sink, and specific interference relations: namely those induced by the dimension $1$ and $2$ Euclidean space, those cases are likely to be the practical ones.
RR-5432.pdf (290.89 Ko) Télécharger le fichier
inria-00070575 , version 1 (19-05-2006)
  • HAL Id : inria-00070575 , version 1
Ralf Klasing, Nelson Morales, Stéphane Pérennes. On the Complexity of Bandwidth Allocation in Radio Networks with Steady Traffic Demands. [Research Report] RR-5432, INRIA. 2004, pp.27. ⟨inria-00070575⟩
187 Consultations
61 Téléchargements
