s'authentifier
version française rss feed
inria-00070632, version 1
Variational Shape Approximation
David Cohen-Steiner () 1, Pierre Alliez () 2, Mathieu Desbrun 3
N° RR-5371 (2004)
Résumé : Achieving efficiency in mesh processing often demands that overly verbose 3D datasets be reduced to more concise, yet faithful representations. Despite numerous applications ranging from geometry compression to reverse engineering, concisely capturing the geometry of a surface remains a tedious task. In this paper, we present both theoretical and practical contributions that result in a novel and versatile framework for geometric approximation of surfaces. We depart from the usual strategy by casting shape approximation as a variational geometric partitioning problem. Using the concept of geometric proxies, we drive the distortion error down through repeated clustering of faces into best-fitting regions. Our approach is entirely discrete and error-driven, and does not require parameterization or local estimations of differential quantities. We also introduce a new metric based on normal deviation, and demonstrate its superior behavior at capturing anisotropy.
  • Domaine : Informatique/Autre
  • Mots-clés : SURFACES / GEOMETRIC APPROXIMATION / GEOMETRIC ERROR METRICS / LLOYD'S CLUSTERING ALGORITHM / ANISOTROPIC REMESHING
  • Référence interne : RR-5371
  • inria-00070632, version 1
  • oai:hal.inria.fr:inria-00070632
  • Contributeur :
  • Soumis le : Vendredi 19 Mai 2006, 21:04:08
  • Dernière modification le : Vendredi 13 Février 2009, 16:49:32
tous les articles de la base du CCSd...
