Optimal Blurred Segments Decomposition in Linear Time - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2004
Fabien Feschet
Blurred (previously named fuzzy) segments were introduced by Debled-Rennesson et al as an extension of the arithmetical approach of Reveillès on discrete lines, to take into account noise in digital images. An incremental linear-time algorithm was presented to decompose a discrete curve into blurred segments with order bounded by a parameter d. However, it fails to segment discrete curves into a minimal number of blurred segments. We identify in this paper, that this characteristic is intrinsic to the whole class of blurred segments. We thus introduce a subclass of blurred segments, based on a geometric measure of thickness. We provide a new convex hull based incremental linear time algorithm for segmenting discrete curves into minimally thin blurred segments.
Autre [cs.OH]
RR-5334.pdf (402.37 Ko) Télécharger le fichier
inria-00070667 , version 1 (19-05-2006)
  • HAL Id : inria-00070667 , version 1
Isabelle Debled-Rennesson, Fabien Feschet, Jocelyne Rouyer-Degli. Optimal Blurred Segments Decomposition in Linear Time. [Research Report] RR-5334, INRIA. 2004, pp.16. ⟨inria-00070667⟩
143 Consultations
545 Téléchargements
