Modelling Dynamic Scenes by Registrating Multi-View Image Sequences - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2004
Renaud Keriven
  • Fonction : Auteur
Olivier Faugeras
We present a new variational method for multi-view stereovision and non-rigid three-dimensional motion estimation from multiple video sequences. Our method minimizes the prediction error of the estimated shape and motion. Both problems then translate into a generic image registration task. The latter is entrusted to a similarity measure chosen depending on imaging conditions and scene properties. In particular, our method can be made robust to appearance changes due to non-Lambertian materials and illumination changes. Our method results in a simpler, more flexible, and more efficient implementation than existing deformable surface approaches. The computation time on large datasets does not exceed thirty minutes. Moreover, our method is compliant with a hardware implementation with graphics processor units. Our stereovision algorithm yields very good results on a variety of datasets including specularities and translucency. We have successfully tested our scene flow algorithm on a very challenging multi-view video sequence of a non-rigid event.
RR-5321.pdf (1.85 Mo) Télécharger le fichier
inria-00070679 , version 1 (19-05-2006)
  • HAL Id : inria-00070679 , version 1
Jean-Philippe Pons, Renaud Keriven, Olivier Faugeras. Modelling Dynamic Scenes by Registrating Multi-View Image Sequences. RR-5321, INRIA. 2004, pp.20. ⟨inria-00070679⟩
99 Consultations
196 Téléchargements
