s'authentifier
version française rss feed
inria-00070702, version 1
Online adaptation of reference trajectories for the control of walking systems
Pierre-Brice Wieber () a1, Christine Chevallereau 2
N° RR-5298 (2004)
Résumé : A simple and widely used way to make a robotic system walkwithout falling is to make it track a reference trajectory in one way or another, but the stability obtained this way may be limited and even small perturbations may lead to a fall. We propose here a series of heuristics to improve the stability that can be obtained from such a tracking control law, through an online adaptation of the choice of the reference trajectory being tracked. Encouraging simulations are obtained in the end on a simple planar biped model.
  • Domaine : Informatique/Autre
  • Mots-clés : ONLINE ADAPTATION / PARAMETRIZED TRAJECTORIES / CONSTRAINED DYNAMICS / WALKING SYSTEMS / VIABILITY
  • Référence interne : RR-5298
  • inria-00070702, version 1
  • oai:hal.inria.fr:inria-00070702
  • Contributeur :
  • Soumis le : Vendredi 19 Mai 2006, 21:15:21
  • Dernière modification le : Jeudi 18 Septembre 2008, 15:05:10
tous les articles de la base du CCSd...
