A tetrahedral-based superconvergent scheme for aeroacoustics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2004
We describe a numerical scheme for hyperbolics well adapted to both aerodynamics and aeroacoustics. The scheme is vertex centered, It applies with second order accuracy to unstructured tetrahedrizations and extends to higher order (up to sixth) on a certain type of cartesian meshes. Several basic aeroacoustic numerical experiments are presented.
RR-5212.pdf (381.55 Ko) Télécharger le fichier
inria-00070781 , version 1 (19-05-2006)
  • HAL Id : inria-00070781 , version 1
Nicolas Gourvitch, Gilbert Rogé, Ilia Abalakin, Alain Dervieux, Tatiana Kozubskaya. A tetrahedral-based superconvergent scheme for aeroacoustics. [Research Report] RR-5212, INRIA. 2004, pp.28. ⟨inria-00070781⟩
136 Consultations
201 Téléchargements
