Explicit Reconstruction for Image Inpainting - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
Image inpainting refers to techniques which allow to fill in a gap $\Omega$ given the intensities around it. In this paper, we focus on geometric image inpainting for which several PDE based models have been proposed. Most of them rely on a transport or/and a diffusion equation of the intensity inside $\Omega$. The direction of the reconstructed isophotes and the gray levels are generally computed in a coupled way. Instead, we propose in this paper a two step approach. First we estimate the tangents of the missing isophotes using a tensor field diffusion process. Then we simply recover the gray levels by integrating along integral curves of the tensors principal eigenvectors. Such an approach has very few parameters to tune and we illustrate its performance on several synthetic and real examples.
Autre [cs.OH]
RR-5905.pdf (731.36 Ko) Télécharger le fichier
inria-00071360 , version 1 (23-05-2006)
  • HAL Id : inria-00071360 , version 1
Pierre Kornprobst, Gilles Aubert. Explicit Reconstruction for Image Inpainting. [Research Report] RR-5905, INRIA. 2006. ⟨inria-00071360⟩
365 Consultations
55 Téléchargements
