Effective Algorithms for Parametrizing Linear Control Systems over Ore Algebras - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2004
Frédéric Chyzak
Alban Quadrat
  • Fonction : Auteur
  • PersonId : 833444
In this paper, we study linear control systems over Ore algebras. Within this mathematical framework, we can simultaneously deal with different classes of linear control systems such as time-varying systems of ordinary differential equations (ODEs), differential time-delay systems, underdetermined systems of partial differential equations (PDEs), multidimensional discrete systems, multidimensional convolutional codes etc. We give effective algorithms which check whether or not a linear control system over some Ore algebra is controllable, parametrizable, flat or Pi-free.
RR-5181.pdf (615.81 Ko) Télécharger le fichier
inria-00071407 , version 1 (23-05-2006)
  • HAL Id : inria-00071407 , version 1
Frédéric Chyzak, Alban Quadrat, Daniel Robertz. Effective Algorithms for Parametrizing Linear Control Systems over Ore Algebras. [Research Report] RR-5181, INRIA. 2004. ⟨inria-00071407⟩
82 Consultations
239 Téléchargements
