Scalable and Modular Scheduling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2004
Scheduling a program (i.e. constructing a timetable for the execution of its operations) is one of the most powerful methods for automatic parallelization. A schedule gives a blueprint for constructing a synchronous program, suitable for an ASIC or VLIW processor. However, constructing a schedule entails solving a large linear program. Even if one accept the (experimental) fact that the Simplex is almost always polynomial, the scheduling time is of the order of a large power of the program size. Hence, the method does not scale well. The present paper proposes two methods for improving the situation. Firstly, a big program can be divided in smaller units (processes) which can be scheduled separately. This is modular scheduling Second, one can use projection methods for solving linear programs incrementatly. This is specially efficient if the dependence graph is sparse.
Autre [cs.OH]
RR-5180.pdf (219.04 Ko) Télécharger le fichier
inria-00071408 , version 1 (23-05-2006)
  • HAL Id : inria-00071408 , version 1
Paul Feautrier. Scalable and Modular Scheduling. RR-5180, INRIA. 2004. ⟨inria-00071408⟩
76 Consultations
220 Téléchargements
