A rigorous and realistic Shape From Shading method and some of its applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2004
Emmanuel Prados
Olivier Faugeras
This article proposes a rigorous and realistic solution of the Lambertian Shape From Shading (SFS) problem. The power of our approach is threefolds. First, our work is based on a rigorous mathematical method: we define a new notion of weak solutions (in the viscosity sense) which does not necessarily requires boundary data (contrary to the work of [rouy-tourin:92,prados-faugeras-etal:02,prados-faugeras:03,camilli-falcone:96,falcone-sagona-etal:01]) and which allows to define a solution as soon as the image is (Lipschitz) continuous (contrary to the work of [oliensis:91,dupuis-oliensis:94]). We prove the existence and uniqueness of this (new) solution and we approximate it by using a provably convergent algorithm. Second, it improves the applicability of the SFS to real images: we complete the realistic work of [prados-faugeras:03,tankus-sochen-etal:03], by modeling the problem with a pinhole camera and with a single point light source located at the optical center. This new modelization appears very relevant for applications. Moreover, our algorithm can deal with images containing discontinuities and black shadows. It is very robust to pixel noise and to errors on parameters. It is also generic: i.e. we propose a unique algorithm which can compute numerical solutions of the various perspective and orthographic SFS models. Finally, our algorithm seems to be the most efficient iterative algorithm of the SFS literature. Third, we propose three applications (in three different areas) based on our SFS method.
RR-5133.pdf (1.31 Mo) Télécharger le fichier
inria-00071450 , version 1 (23-05-2006)
  • HAL Id : inria-00071450 , version 1
Emmanuel Prados, Olivier Faugeras. A rigorous and realistic Shape From Shading method and some of its applications. RR-5133, INRIA. 2004. ⟨inria-00071450⟩
400 Consultations
313 Téléchargements
