Numerical Simulation of the 2D Non-Parabolic MEP Energy-Transport Model with a Mixed Finite Elements Scheme - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2004
V. Romano
  • Fonction : Auteur
J.M. Sellier
  • Fonction : Auteur
In the Mixed Finite Element approximation scheme has been used to simulate a consistent hydrodynamical model for electron transport in semiconductors, free of any fitting parameters , based on the Maximum Entropy Principle (MEP) and assuming the Parabolic Band approximation. In this paper we describe an application of the above numerical method in the case of the two dimensional Non-Parabolic MEP energy-transport model. We can consider this paper as a generalization of what has been done in . As done in results of the simulation of 2D-MESFET and 2D-MOSFET Silicon devices are presented.
RR-5103.pdf (8.02 Mo) Télécharger le fichier
inria-00071480 , version 1 (23-05-2006)
  • HAL Id : inria-00071480 , version 1
Americo Marrocco, V. Romano, J.M. Sellier. Numerical Simulation of the 2D Non-Parabolic MEP Energy-Transport Model with a Mixed Finite Elements Scheme. [Research Report] RR-5103, INRIA. 2004. ⟨inria-00071480⟩
81 Consultations
150 Téléchargements
