Sorting by reversals in subquadratic time - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2004
Eric Tannier
Marie-France Sagot
The problem of sorting by signed reversals is inspired by a genome rearrangement problem in computational molecular biology. Given two genomes represented as signed permutations of the same elements (e.g. orthologous genes), the problem consists in finding a most parsimonious scenario of reversals that transforms one genome into the other. We propose a method for sorting a signed permutation by reversals in time O(n). The best known algorithms run in time O(n^2), the main obstacle to an improvement being a costly operation of detection of so-called «safe» reversals. We bypass this detection and, using the same data structure as a previous random approximation algorithm, we achieve the same subquadratic complexity for finding an exact optimal solution. This answers an open question by Ozery-Flato and Shamir whether a subquadratic complexity could ever be achieved for solving the problem.
RR-5097.pdf (224.56 Ko) Télécharger le fichier
inria-00071486 , version 1 (23-05-2006)
  • HAL Id : inria-00071486 , version 1
Eric Tannier, Marie-France Sagot. Sorting by reversals in subquadratic time. [Research Report] RR-5097, INRIA. 2004. ⟨inria-00071486⟩
79 Consultations
215 Téléchargements
