Extracting meaningful curves from images - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2003
Since the beginning, Mathematical Morphology has proposed to extract shapes from images as connected components of level sets. These methods have proved very efficient in shape recognition and shape analysis. In this paper, we present an improved method to select the most meaningful level lines (boundaries of level sets) from an image. This extraction can be based on statistical arguments, leading to a parameter free algorithm. It permits to roughly extract all pieces of level lines of an image, that coincide with pieces of edges. By this method, the number of encoded level lines is reduced by a factor 100, without any loss of shape contents. In contrast to edge detections algorithm or snakes methods, such a level lines selection method delivers accurate shape elements, without user parameter: no smoothing involved and selection parameters can be computed by Helmholtz Principle.
RR-5067.pdf (1.7 Mo) Télécharger le fichier
inria-00071517 , version 1 (23-05-2006)
  • HAL Id : inria-00071517 , version 1
Frédéric Cao, Pablo Musé, Frédéric Sur. Extracting meaningful curves from images. [Research Report] RR-5067, INRIA. 2003. ⟨inria-00071517⟩
135 Consultations
1676 Téléchargements
