Toward IPv6 OLSR - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2003
Toward IPv6 OLSR
Anis Laouiti
Pascale Minet
Cédric Adjih
The first part of this document describes the features of IPv6; such as the different address formats, the neighbor discovery protocol, and the autoconfiguration procedure. The second part is dedicated to the changes required for OLSR to work, and to benefit from IPv6 mechanisms.
Autre [cs.OH]
RR-4997.pdf (194.69 Ko) Télécharger le fichier
inria-00071581 , version 1 (23-05-2006)
  • HAL Id : inria-00071581 , version 1
Anis Laouiti, Pascale Minet, Cédric Adjih. Toward IPv6 OLSR. [Research Report] RR-4997, INRIA. 2003. ⟨inria-00071581⟩
183 Consultations
113 Téléchargements
