Generalizing CASL Specification Components and Preserving Rewrite Proofs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2003
We propose the theoretical basis of a tool for the generation of reusable CASL specification components by generalization of existing ones. The underlying idea is, given a component and a set of semantic properties that it satisfies and that we want to preserve, to find a parameterized, more general, component satisfying the following conditions: the original component is one of its possible instantiations, and any of its instantiations satisfy the stated properties. We present here both the definition of the generalization operation for CASL and the problem of preserving properties in the generalized component. To guarantee the preservation of properties, we propose to preserve their proofs, concentrating on the use of rewrite proofs. This technique provides a simple way to find sufficient conditions for the preservation of the corresponding properties. This work is being integrated in the specification component development tool FERUS, under development for the CASL language, using ELAN as the rewrite proof engine.
RR-4938.pdf (406.08 Ko) Télécharger le fichier
inria-00071641 , version 1 (23-05-2006)
  • HAL Id : inria-00071641 , version 1
Anamaria Martins, Christophe Ringeissen. Generalizing CASL Specification Components and Preserving Rewrite Proofs. [Research Report] RR-4938, INRIA. 2003, pp.34. ⟨inria-00071641⟩
75 Consultations
177 Téléchargements
