Aeroelastic coupling in sonic boom optimization of a supersonic aircraft - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2003
In this paper, we consider a multi-disciplinary optimization problem where the initial shape of a wing is sought in order to cope, after elastic deformation by the flow, with some optimality conditions. We propose a medium-strong coupling which allows to consider different softwares communicating a small number of times. Applications to the optimization of the AGARD Wing 445.6 and a flexible supersonic aircraft wing are presented.
RR-4865.pdf (905.9 Ko) Télécharger le fichier
inria-00071718 , version 1 (23-05-2006)
  • HAL Id : inria-00071718 , version 1
Mariano Vázquez, Alain Dervieux, Bruno Koobus. Aeroelastic coupling in sonic boom optimization of a supersonic aircraft. [Research Report] RR-4865, INRIA. 2003. ⟨inria-00071718⟩
112 Consultations
147 Téléchargements
