Combinatorial approaches for segmentingbacterium genomes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2003
Bacterium genome plasticity analysis can efficiently be performed by Long-Range PCR (Polymerase Chain Reaction). The first step requires to split the genome into hundreds of short overlapping segments which, after amplification, are used to sketch the profile of different bacterium strains. The segments to be amplified are determined using a reference bacterium strain. They have to cover the entire genome and to be of nearly identical size. In this report, we use an interval graph for presenting the segments and their position. We show that the most appropriate choice for such segments is equivalent to solving a kind of Shortest Path Problem on a subgraph of the interval graph called covering graph. We propose two optimization models for this problem. These models correspond to two criteria for measuring the quality of the covering; (i) the maximal deviation of the segments lengths from a given ideal length should be minimal, (ii) to find a length such that that maximal deviation from it is minimal. For each criterium we derive two algorithms of linear complexity in respect to the number of arcs in the graph.
Autre [cs.OH]
RR-4853.pdf (334.89 Ko) Télécharger le fichier
inria-00071730 , version 1 (23-05-2006)
  • HAL Id : inria-00071730 , version 1
Rumen Andonov, Nicola Yanev, Dominique Lavenier, Philippe Veber. Combinatorial approaches for segmentingbacterium genomes. [Research Report] RR-4853, INRIA. 2003. ⟨inria-00071730⟩
186 Consultations
92 Téléchargements
