Determination of Moment Invariants and Their Application to Visual Servoing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2003
Omar Tahri
  • Fonction : Auteur
  • PersonId : 753133
  • IdHAL : omar-tahri
Moment invariants are important shape descriptors in computer vision. In this paper, we give a general and systematic method to derive moment invariants of any order and for k-dimensional space (invariants to scale, to orthogonal transformation and to translation). This result is applied to the selection of adequate features for visual servoing. To elaborate the control law, we also determine the analytical form of the interaction matrix of any image moment. This matrix relates the variation of the image moments to the 3D motions of the camera. We finally presents some visual servoing experimental results using very simple images. These results allow to validate the theoretical developments proposed in this paper.
Autre [cs.OH]
RR-4845.pdf (420.54 Ko) Télécharger le fichier
inria-00071738 , version 1 (23-05-2006)
  • HAL Id : inria-00071738 , version 1
Omar Tahri, François Chaumette. Determination of Moment Invariants and Their Application to Visual Servoing. [Research Report] RR-4845, INRIA. 2003. ⟨inria-00071738⟩
158 Consultations
383 Téléchargements
