Comments on «Dynamical properties of hybrid automata», IEEE Trans. on Automatic Control, vol.48, pp.2-14, 2003 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2003
The above-mentioned paper contains a general analysis of hybrid dynamical systems. Well-posedness and stability results are presented. In this note we point out some limitations of these results which are somewhat hidden by a quite unfortunate choice of the illustrating example. Actually it happens that so-called complementarity mechanical systems are, to a large extent, outside the scope of the developed theory, contrary to what the example might let one believe.
Autre [cs.OH]
RR-4839.pdf (219.19 Ko) Télécharger le fichier
inria-00071746 , version 1 (23-05-2006)
  • HAL Id : inria-00071746 , version 1
Bernard Brogliato. Comments on «Dynamical properties of hybrid automata», IEEE Trans. on Automatic Control, vol.48, pp.2-14, 2003. RR-4839, INRIA. 2003. ⟨inria-00071746⟩
88 Consultations
115 Téléchargements
