Finite Volume simulation of cavitating flows - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2003
In this work, we propose a numerical method for the modelling of phase transitions in compressible fluid flows. The pressure laws taking into account phase transitions are complex and lead to difficulties such as the non-uniqueness of the entropy solutions. In order to avoid these difficulties, we propose a projection finite volume scheme. It is based on a Riemann solver with a simpler pressure law and an entropy maximization procedure in order to recover the original complex pressure law. Several numerical experiments are presented which validate this approach.
Autre [cs.OH]
RR-4824.pdf (501.9 Ko) Télécharger le fichier
inria-00071762 , version 1 (23-05-2006)
  • HAL Id : inria-00071762 , version 1
Philippe Helluy, Thomas Barberon. Finite Volume simulation of cavitating flows. RR-4824, INRIA. 2003. ⟨inria-00071762⟩
110 Consultations
356 Téléchargements
