Exploiting Symmetries to Test Programs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2003
Arnaud Gotlieb
  • Fonction : Auteur
  • PersonId : 830099
Symmetries often appear as properties of many artifical settings. In Program Testing, they can be viewed as properties of programs and can be used to check the correctness of the computed outcomes. In this paper, we consider symmetries to be permutation relations between program executions and use them to automate the testing process. We introduce a software testing paradigm called Symmetric Testing, where automatic test data generation is coupled with symmetries checking to uncover faults inside the programs. A practical procedure for checking that a program satisfies a given symmetry relation is described. The paradigm makes use of Group theoretic results as a formal basis to minimize the number of program executions required by the method. This approach appears to be of particular interest for programs for which neither an oracle, nor any formal specification is available. We implemented Symmetric Testing by using the primitive operations of Roast : a Java unit testing tool developped by N. Daley, D. Hoffman and P. Strooper. The experimental results we got on faulty versions of classical programs of the Software Testing community show the effectiveness of the approach.
Autre [cs.OH]
RR-4810.pdf (345.14 Ko) Télécharger le fichier
inria-00071776 , version 1 (23-05-2006)
  • HAL Id : inria-00071776 , version 1
Arnaud Gotlieb. Exploiting Symmetries to Test Programs. [Research Report] RR-4810, INRIA. 2003. ⟨inria-00071776⟩
55 Consultations
245 Téléchargements
