The SANDRA project: cooperative architecture/compiler technology for embedded real-time streaming applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2003
Albert Cohen
Marc Duranton
  • Fonction : Auteur
Christine Eisenbeis
  • Fonction : Auteur
  • PersonId : 833430
Paul Feautrier
Daniela Genius
  • Fonction : Auteur
Laurent Pasquier
  • Fonction : Auteur
Valérie Rivierre-Vier
  • Fonction : Auteur
Qin Zhao
  • Fonction : Auteur
The convergence of digital television, Internet access, gaming, and digital media capture and playback stresses the importance of high-quality and high-performance video and graphics processing. The SANDRA project, a collaboration between Philips Research and INRIA, develops a consistent and efficient system design approach for regular, real-time constrained stream processing. The project aims at providing a system template with its associated compiler chain and application development framework, enabling an early validation of both the functional and the non-functional requirements of the application at every system design stage.
RR-4773.pdf (136.8 Ko) Télécharger le fichier
inria-00071813 , version 1 (23-05-2006)
  • HAL Id : inria-00071813 , version 1
Zbigniew Chamski, Albert Cohen, Marc Duranton, Christine Eisenbeis, Paul Feautrier, et al.. The SANDRA project: cooperative architecture/compiler technology for embedded real-time streaming applications. [Research Report] RR-4773, INRIA. 2003. ⟨inria-00071813⟩
258 Consultations
284 Téléchargements
