On a Kinetic Equation for Coalescing Particles - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2003
Miguel Escobedo
  • Fonction : Auteur
Philippe Laurençot
Existence of global weak solutions to a spatially inhomogeneous kinetic model for coalescing particles is proved, each particle being identified by its mass, momentum and position. The large time convergence to zero is also shown. The cornestone of our analysis is that, for any nonnegative and convex function, the associated Orlicz norm is a Liapunov functional. Existence and asymptotic behaviour then rely on weak and strong compactness methods in L^1 in the spirit of the DiPerna-Lions theory for the Boltzmann equation.
RR-4748.pdf (483.57 Ko) Télécharger le fichier
inria-00071839 , version 1 (23-05-2006)
  • HAL Id : inria-00071839 , version 1
Miguel Escobedo, Philippe Laurençot, Stéphane Mischler. On a Kinetic Equation for Coalescing Particles. [Research Report] RR-4748, INRIA. 2003. ⟨inria-00071839⟩
109 Consultations
311 Téléchargements
