s'authentifier
version française rss feed
inria-00071863, version 1
Approximation of Normal Cycles
David Cohen-Steiner () 1, Jean-Marie Morvan
N° RR-4723 (2003)
Résumé : This report deals with approximations of geometric data defined on a hypersurf- ace of the Euclidean space E^n. Using geometric measure theory, we evaluate an upper bound on the flat norm of the difference of the normal cycle of a compact subset of E^n whose boundary is a smooth (closed oriented embedded) hypersurface, and the normal cycle of a compact geometric subset of E^n "close to it". We deduce bounds between the difference of the curvature measures of the smooth hypersurface and the curvature measures of the geometric compact subset.
  • Domaine : Informatique/Autre
  • Mots-clés : NORMAL CYCLE / APPROXIMATION / SURFACE / CURVATURE
  • Référence interne : RR-4723
  • inria-00071863, version 1
  • oai:hal.inria.fr:inria-00071863
  • Contributeur :
  • Soumis le : Mardi 23 Mai 2006, 19:02:48
  • Dernière modification le : Mercredi 31 Mai 2006, 14:24:25
tous les articles de la base du CCSd...
