A simple test qualifying the accuracy of Horner's rule for polynomials - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Numerical Algorithms Année : 2004
Sylvie Boldo
Marc Daumas
  • Fonction : Auteur
Polynomials are used in many applications and hidden in libraries such as libm. Whereas the accuracy of the functions used by linear algebra have long been studied, little is available to decide on one scheme to evaluate a polynomial. Common knowledge solely emphasizes that Horner's rule is a good scheme unless the indeterminate is close to one of the polynomial's roots. We propose here a criterion for one step of Horner's scheme to be faithful. A result is defined to be faithful when it was correctly rounded whereas the rounding mode (up, down or to the nearest) cannot be known by the user. Our criterion is checked against the IEEE standard for floating point arithmetic using the Coq automatic proof checker. We then present three programs in Maple, Java and C that check the criterion for a whole polynomial associated with a domain for the indeterminate and a possible truncation error. An example of use is given with the approximation of elementary functions.
Autre [cs.OH]
RR-4707.pdf (287.66 Ko) Télécharger le fichier
inria-00071879 , version 1 (23-05-2006)
Sylvie Boldo, Marc Daumas. A simple test qualifying the accuracy of Horner's rule for polynomials. Numerical Algorithms, 2004, 37 (1-4), pp.45-60. ⟨10.1023/B:NUMA.0000049487.98618.61⟩. ⟨inria-00071879⟩
248 Consultations
1526 Téléchargements
