A Quasi-Newton Algorithm Based on a Reduced Model for Fluid-Structure Interaction Problems in Blood Flows - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2003
We propose a quasi-Newton algorithm for solving fluid-structure interaction problems. The basic idea of the method is to build an approximate tangent operator which is cost effective and which takes into account the so-called added mass effect. Various test cases show that the method allows a significant reduction of the computational effort compared to relaxed fixed point algorithms. We present 2D and 3D fluid-structure simulations performed either with a simple 1D structure model or with shells in large displacements.
Autre [cs.OH]
RR-4691.pdf (395.46 Ko) Télécharger le fichier
inria-00071895 , version 1 (23-05-2006)
  • HAL Id : inria-00071895 , version 1
Jean-Frédéric Gerbeau, Marina Vidrascu. A Quasi-Newton Algorithm Based on a Reduced Model for Fluid-Structure Interaction Problems in Blood Flows. [Research Report] RR-4691, INRIA. 2003. ⟨inria-00071895⟩
217 Consultations
740 Téléchargements
