Synchronous Modeling of Modular Avionics Architectures using the SIGNAL Language - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2002
This document presents a study on the modeling of architecture components for avionics applications. We consider the avionics standard ARINC 653 specifications as basis, as well as the synchronous language SIGNAL to describe the modeling. A library of APEX object models (partition, process, communication and synchronization services, etc.) has been implemented. This should allow to describe distributed real-time applications using POLYCHRONY, so as to access formal tools and techniques for architecture evaluation.
Autre [cs.OH]
RR-4678.pdf (1.21 Mo) Télécharger le fichier
inria-00071907 , version 1 (23-05-2006)
  • HAL Id : inria-00071907 , version 1
Abdoulaye Gamatié, Thierry Gautier. Synchronous Modeling of Modular Avionics Architectures using the SIGNAL Language. [Research Report] RR-4678, INRIA. 2002. ⟨inria-00071907⟩
182 Consultations
812 Téléchargements
