Towards Self-Adaptive Parameterization of Bézier Curves for Airfoil Aerodynamic Design - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2002
This report is part of a series of numerical studies in optimum-shape design in aerodynamics in which the equations of Fluid Mechanics (typically the Euler Equations for Compressible Perfect Gas) are solved by a Finite-Volum- e-type method over a structured or unstructured mesh, and the aerodynamic shape (wing or airfoil) is optimized w.r.t. some aerodynamic criterion (e.g. lift maximization or drag reduction). We are considering here the two-dimensionnal case in which the shape is an airfoil represented by a Bézier curve whose degree is much smaller than the number of meshpoints on the body surface and we assume that the control points have a priori fixed abscissas and that their ordinates constitute the set of parameters of the optimization. We evaluate by numerical experiments the incidence of this a priori choice on the efficacy of the optimization.
Autre [cs.OH]
RR-4572.pdf (455.03 Ko) Télécharger le fichier
inria-00072016 , version 1 (23-05-2006)
  • HAL Id : inria-00072016 , version 1
Zhi Li Tang, Jean-Antoine Desideri. Towards Self-Adaptive Parameterization of Bézier Curves for Airfoil Aerodynamic Design. [Research Report] RR-4572, INRIA. 2002. ⟨inria-00072016⟩
203 Consultations
771 Téléchargements
