The Design of GCCL: a Generalized Common Contract Language - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2002
Following its inception in Eiffel by Meyer and its diffusion to other environments (e.g., the standardisation of OCL as part of UML), Design by Contract now faces a major challenge in component-based software engineerin- g (CBSE). Compositional reasoning about system properties from component ones has been recently asserted by the SEI as the "key technical challenge" of CBSE, and contracts as a "key technical concept to support this vision". To live up to these expectations, DbC must tackle extra-functional properties of components and support Klein's "architectural-based attribute reasoning." Besides adopting the necessary new concepts, a good contract language must provide for abstraction, application, composition and scoping mechanisms in such a way to be used from modeling in UML to programming in standard languages (as seamless extensions to Java, C#, C++, Eiffel, and so on) through execution on traditional operating systems with minimal middleware additions. This paper examines conceptual foundations and design decisions to propose GCCL, a novel open generalized common contract language. GCCL is meant to be compatible with existing DbC (sub)languages, and especially OCL.
RR-4502.pdf (322.02 Ko) Télécharger le fichier
inria-00072086 , version 1 (23-05-2006)
  • HAL Id : inria-00072086 , version 1
Jacques Malenfant, Noël Plouzeau, Jean-Marc Jézéquel. The Design of GCCL: a Generalized Common Contract Language. [Research Report] RR-4502, INRIA. 2002. ⟨inria-00072086⟩
179 Consultations
85 Téléchargements
