On Combining Functional Verification and Performance Evaluation using CADP - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2002
Considering functional correctness and performance evaluation in a common framework is desirable, both for scientific and economic reasons. In this report, we describe how the CADP toolbox, originally designed for verifying the functional correctness of LOTOS specifications, can also be used for performance evaluation. We illustrate the proposed approach by the performance study of the SCSI-2 bus arbitration protocol.
RR-4492.pdf (234.73 Ko) Télécharger le fichier
inria-00072096 , version 1 (23-05-2006)
  • HAL Id : inria-00072096 , version 1
Hubert Garavel, Holger Hermanns. On Combining Functional Verification and Performance Evaluation using CADP. [Research Report] RR-4492, INRIA. 2002. ⟨inria-00072096⟩
100 Consultations
296 Téléchargements
